Socket error when trying to import entities
I am getting a socket error when I try to import entities from file, which is strange as I am importing from a local file. Binary and xml return the same error. The app log only returns the 5 lines below. Any help is appreciated.
2019-08-20 17:42:16.193-0400 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: ] [S: ] [T: pool-13-thread-1] Thingworx System Metrics_-----------------------------------------------------------------$
2019-08-20 17:42:26.271-0400 [L: ERROR] [O: E.c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: https-jsse-nio-443-exec-6] [message: java.net.SocketTimeoutException]
2019-08-20 17:42:26.274-0400 [L: ERROR] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: https-jsse-nio-443-exec-6] Invalid request: org.apache.catalina.connector.ClientAbortException: java.net.Soc$
2019-08-20 17:42:26.274-0400 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: https-jsse-nio-443-exec-6] Start post migrating from version [8.3.0] to version [8.3.0] ...
2019-08-20 17:42:26.274-0400 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: https-jsse-nio-443-exec-6] Finished post migrating from version [8.3.0] to version [8.3.0].
clansdaleAnswer
Turns out it was an error from WSEMS on the client side that occurred after I upgraded from TW 7.4 to 8.1.
@clansdale
Maybe the firewall is blocking Binary/XML imports.
1. Can you check the value of the parameter connectionTimeout in server.xml of Tomcat?
2. Please send the Tomcat logs, we might find more relevant information there as well
For more info, you can refer to this article and this
@clansdale I just wanted to follow up with you to see if previous response was helpful for your question?
If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question.
Vibhuti
clansdale1-VisitorAuthorAnswer
