Solution Framework
Do we need to install Manufacturing common building blocks before importing solution framework.
I can see pre-requisite as
  • PTC Solutions Common Building Blocks must be installed prior to installing the Solution Framework
Can anybody clarify whether common building block is 'mfg1-2' extension
@SP_10701000
I think you are following the "Installation Prerequisites" sections of TWX Solution Framework from below link.
https://github.com/PTCInc/twx-solution-framework/releases
I have not tested this. But I think you should follow the "6.Download the Building Blocks Using the Software Downloads Page" sectoin to install the latest version MFG-Common-1-2 (1 MB).
https://support.ptc.com/help/building_blocks/r1.1/en/index.html#page/bb/building_blocks/getting_started_with_building_blocks/deploying_building_blocks_using_ptc_software_downloads_page.html#wwID0ESHCK
