Sorting an infotable based on order specified
I am trying to sort an infotable result set based on specific order (array)
Example:
My Infotable result set:
Column1 Column2 Column3
d desc1 desc one
h desc2 desc two
f desc3 desc three
t desc4 desc four
My order to sort  ::  [f,t,h,d]
Expected result set after sorting
f desc3 desc three
t desc4 desc four
h desc2 desc two
d desc1 desc one
Would highly appreciate a quick turnaround.
Thanks in advance.
Not super efficient, but should work:
function sort(array,sortOrder,sortColumn) {
 function sortFunc(a, b) {
 return sortOrder.indexOf(a[sortColumn]) - sortOrder.indexOf(b[sortColumn]);
 var temp = [];
 for each(row in array.rows) temp.push(row);
 var nItems = array.rows.length;
 for (var i=0;i<nItems;i++) delete array.rows[0];
 temp.sort(sortFunc);
 for (var i=0;i<temp.length;i++) array.AddRow(temp[i]);
sort(result,['f','t','h','d'],'column1');
 var temp = [];
Thanks Carles it worked 🙂
