Sparkplug Specification support in ThingWorx
Hi All,
Do we have any kind of decoders available for ThingWorx to read the MQTT data with Sparkplug Specification?
Currently I can read the data in encrypted format but I wanted to get it decrypted and get it as a JSON. Any help to understand this is appreciated.
Thanks.
Support
Hi @VK_10079185.
Unless one of our developers in the community have experience with this, you may have to Google it for more information.  Have you tried decrypting it before reaching ThingWorx?
--Sharon
11-Garnet
+1 on this...
After briefly looking on internet I was able to find a Java example here that you probably can take as an example to build your own Java extension for decoding the message:
https://github.com/Cirrus-Link/Sparkplug/blob/master/sparkplug_b/stand_alone_examples/java/src/main/java/com/cirruslink/example/SparkplugExample.java
I'm pretty sure there are also Javascript examples, though not sure about their dependencies hence my suggestion to use Java.
11-Garnet
My research has provided similar results, that the next step will probably be an extension if the project goes that far.  Thanks for the comment.
