Speed up CRUD operations on Stream
Hi to you all,
Create and Update Entry upon Stream take too long
I read here that updates and writes on stream are configured async. I want to reduce the time between executing updateStreamEntry on a row and see the result on the stream. I was trying to change async to sync to speed up operations on stream, it will charge a bit more my server but i have resources so it is ok fotr me.
I opened the configuration for thingworxPersistenceProvider but i can't find any checkbox for sync or async could you please guide me how to change parameters ( i think with updateStreamDataProcessingSettings ) for having a writing time less than 1 second ?
