Split infotable based on Property value
I would like to split my infotable into as many infotable as there are values that a given property assumes.
For example this is the original infotable
And these the derived infotables
How can I get this???
@PB_9026895,
Don't understand what you are trying to accomplish. You can can write a script which accepts or access a value "customer" and the source InfoTable.
You could then create a new InfoTable in your script and return the rows which match the customer supplied.
I may have not understood your question so please clarify what information you need and I will try to help
Peter
