Splitting or matching a string in a service
I want to take a part of input string and compare it with an existing string and store it. There are functions like split, splice , includes, etc in JS but I am unable to use them. How can I achieve the functionality?
18-Opal
Those two lines are equivalent to the code snippet that you provided in your previous message, just shorter.
You can use substring:
var str = "This contains a string.";
var cut = str.substring(2,11); // cut = "is contai"
Just checked it, can you tell me why it isn't working in the infotable for loop? outside the loop it works fine! The thing is, I am comparing the string with another string which is in the infotable
18-Opal
@gourinaik98, can you show an example of your code where it doesn't work?
