SQL connection by domain account
due to some legal requirements im not able use login by local account to SQL database (this way work perfektly), I need set connection based on Domain account, but if I use domain\user and password, each time im getting error
"Unable to Invoke Service Test on test domain connection_II: null"
Any Idea how to solve
(as thing template Im using JDBC_MSSQLServer)
20-Turquoise
You have to authenticate with a username (enabled login SQL options).
mschenk1-VisitorAuthor
Hi, I make it (if I used SQL management studio I can use windows authentication), but issue is same, I checked log in SQL and there is
Login failed for user 'eu\xxx. Reason: Attempting to use an NT account name with SQL Server Authentication.[CLIENTxxxxxx]
Error: 18456, Severity: 14, State: 6.
if you are using windows authentication try using SQL Server User credentials
or try with using sa user in configurations on ThingWorx entity
