SQL Query/Command with complex parameters?
Hello everybody,
is there a way how I can use complex parameters (INFOTABLE or JSON) for SQL Query/Commands?
Normally i need to add all columns I need as parameter. For large tables with many columns this can be really annoying.
In the script I can use "<< >>" or "[[ ]]" to substitute parameters, but how can I do it, when the parameter is a JSON? e.g.: entry = { "id": 1, "val": "Hello" }.
Every try of an SQL script trying to access "entry.val" does not work for me ...
Greetings
Andreas
jenscAnswer
If you are still looking for ways to do this, or if someone else ends up finding this post here is some information:
There doesn't seem to be any way to do this out of the box using Infotables, which is unfortunate.
However you can do it using JSON (and that also enables some things you can do with the "rows" array of your infotable).
MSSQL has some JSON functions you can use.
Here is a link to the Microsoft website explaining the use of it.
Jens
jensc17-PeridotAnswer
Jens
