SSO Logout Issue in View App – Credentials Persist and Prevent New User Login
Hello everyone,
I am currently facing an issue with Single Sign-On (SSO) in the Vuforia View app (iPad) and would appreciate any guidance or best practices.
Scenario
- I log into the Vuforia View app using SSO (Microsoft Entra ID).
- The login works as expected.
- However, the app persists the session/credentials internally.
Problem
- I have implemented a logout flow from Microsoft Entra ID.
- When clicking logout, the Microsoft logout window appears successfully.
- However, after logout:
- The Vuforia View app automatically logs the same user back in
- It appears that the app still uses stored cookies/session data
Impact
- A different user cannot log in after logout
- The only way to allow a new user login is:
- Manually going to Settings → Remove Credentials & Cookies
- Only after that, the login screen (SSO window) appears again
Requirement
I want to achieve the following behavior:
- After logout, the next user should be able to log in via SSO
- No credentials/session should persist at the app level
- Ideally, this should happen programmatically or automatically, without manual intervention
- Is there a way to clear cookies/session programmatically in Vuforia View?
- Or is there a recommended approach to force fresh SSO login every time?
- Has anyone implemented a solution for multi-user / shared device scenarios?
Any suggestions, workarounds, or architecture recommendations would be highly appreciated.
Thanks in advance!
