SSO - Thingworx 8.3.3- Pingfederate - Entity Access
Hello All,
We have configured Thingworx8.3.3 with Pingfederate for SSO experience and TW developer is able to access  TW composer with SSO but when developer is trying to access any entities, developer is getting an error "You do not have permission to view" .  How to move users into TW Administrators group when Thingworx composer running with SSO.
We are using the components for PoC
Thingworx server
Pingfederate as Central Auth Server
Enterprise identity provider (IdP) - LDAP
Not sure where am missing configuration step. Need help.
Thanks in advance.
Hello @ nmohammed ,
Have you tried to set the User Provisioning Modification to Enabled . This feature allow future updates to accounts during subsequent login events after the initial login when the user was created to synchronize the ThingWorx user data with the user account data in the identity provider.
You would need to check in which category you are based on the SSO ThingworxSSOAuthenticator Options documentation.
Thank you,
Hello @ nmohammed ,
Thank you,
nmohammed12-AmethystAuthor
Thanks a lot. issue got resolved.
we missed the option of Thingworx SSO authenticator at Security group.
