SSO via REST
Hi all,
is it possible to access the SSO (Single sign on) configuration via REST?
Thanks in advance.
nmutterAnswer
You can reach configuration via standard TWX REST API. To get configuration you will call services like GetConfigurationTable or SetConfigurationTable on the entity "<host>/Thingworx/Authenticators/ThingworxSSOAuthenticator".
To authenticate you will need to have an AppKey with needed permissions (or if SSO is NOT enabled via BasicAuth).
nmutter17-PeridotAnswer
