8-Gravel
SSO with PingFederate vs REST call
Hi Devs,
I have a working SSO configuration using PingFederate - I can log in with the user from my IdP.
The problem I have is the REST API call using AppKey. I created appKey and assigned it to the user. When I try to call service using REST, as a response I get the HTML page from PingFederate with a HTML form and Base64 encoded SAML request as an input in that form.
What I expected was the regular REST call bypassing the SSO.
Is there a possibility to overcome SSO when calling REST?
Thingworx 8.2
7-Bedrock
There is a support article https://www.ptc.com/en/support/article?n=CS279189 describing steps needed.
But basicaly You need to modify sso-settings.json:
    "BasicSettings": {
    "ApplicationKeySettings": {
        "enabled": true
 to have  ApplicationKeySettings.enabled=true
7-Bedrock
    "BasicSettings": {
        "enabled": true
