state definition
hi,
I  create a mashup for adjusting threshold of alerts and I create also a mashup using progress gauge, but my problem is : when I change the thresholds, I can't change the color of the state definition that is connected to it.
thank you in advance.
Anass
raluca_edu
I didn't find any service for what you are asking.
Raluca Edu
hi @raluca_edu ,
Thank you for your response. I think its a bit complicated to do that service.
Have a good day
Support
Hi @anassNasser.
Have you found a solution for your issue?  If so, please post it here and mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
