State Formatting Label Chart
Hello Guys,
Is it possible to do a State Formatting not by fixed values for a label chart? For example  the main value is 24 581  and  I want that the bar is red when it hits below 25 percentage of that value.
22-Sapphire I
I don't know if % formatting is possible (yet) or not - I would put that in the Ideas/Request forum.
You can set the limits dynamically, so you can calculate and provide the limits with a service to your widget properties.
When you add state based formatting to a widget, the limits will become available as bindable properties.
