Storing Static Data in Tw.
How can we store static table with multiple rows and columns in thingworx?
Instead of calling it from external server like sql, Is it possible to store data in thingworx and call it and assign to grid or combo box?
Is it possible to make it by writing a java script and store them? If so what is the return type for java script to be given in tw?
Please provide some guidance.
V.Shalini.
shalini visveswaraiya​: I believe you can store them in a Data table using specific data shape as per your need. There are standard services which you can use in JavaScript or mashup to get the data set from Data table. Please refer to Help center for best practices on data table usage.
-Durgesh
