Stream AddStreamEntry overwrites the data
hello, i am trying to cache some data, so: i have a service that has its output as an InfoTable and retrieves a couple of rows and 5 columns of data. i would like to cache this service as it takes some time to run, but the below code only caches the last row form the server even thought the loop is ok and reads all the rows. (that s why i aded the ii object, for debugging purposes) in monitoring i could not find anything. i also wanted to try the AddStreamEntries service but i got stuck with its implementation
can you please help?
var values;
var params = {
	infoTableName : "InfoTable",
	dataShapeName : "GabiDS"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(AMTable_ModuleDDS_CRA_PG)
var table = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
 var tags = new Array();
 var timestamp = new Date();
	// result: INFOTABLE dataShape: AMTable_ModuleDDS_CRA_PG
	var actions = Things["GabiThing"].GetData();
 if (actions) {
 // loop through infotable
 if(Things["GabiStream"]){
 var params = {
 endDate: timestamp /* DATETIME */,
 immediate: true /* BOOLEAN */,
 startDate: undefined /* DATETIME */
 // no return
 Things["GabiStream"].PurgeStreamEntries(params);
 var tableLength = actions.rows.length;
 for (var x = 0; x < tableLength; x++) {
 var row = actions[x];
 values = Things["GabiStream"].CreateValues();
 try {
 values.x = row.x; //INTEGER
 } catch (err) {
 logger.error('x is null');
 try {
 values.y = row.y; //INTEGER
 } catch (err) {
 logger.error('y is null');
 try {
 values.z = row.z; //INTEGER
 } catch (err) {
 logger.error('z is null');
 try {
 values.t = row.t; //INTEGER
 } catch (err) {
 logger.error('t is null');
 var ii = new Object();
 ii.x = row.x;
 ii.y = row.y;
 ii.z = row.z;
 ii.t = row.t;
 table.AddRow(ii);
 var location = new Object();
 location.latitude = 0;
 location.longitude = 0;
 location.elevation = 0;
 location.units ="WGS84";
 var params = {
 tags : tags,
 timestamp : timestamp,
 source : me.name,
 values : values,
 Things["GabiStream"].AddStreamEntry(params);
var result = table;
jwasneyAnswer
I ran across this the other day.  I was only getting 1/20th of my data in the stream due to the timestamp.  To fix this I set timestamp = new Date(Date.now() + (i * 10));  That ensured there were no duplicate timestamps.
Does the 'table' for which you are add a new row ('ii', in your example) get created properly?
I'm confused because I see you creating this 'values' variable, and then setting the values in your loop (ex: values.t = row.t), but then after you set them, I don't see you doing anything further with the 'values' variable.
Am I missing something?
gabitudor1-VisitorAuthor
That table is only created for the debugging purposes, to see if in for loop takes all the data from GetData service. But "values" is basically the row that is added in the stream, if you look closer
Okay, I see. Then the only other two things I can think of are this:
1. I would make sure your timestamps aren't identical in any of the entries. I believe that if you and add entries to a steam that have identical time stamps and locations (and/or source  -  you'd have to look that up, not sure off the top of my head), I believe they'll begin to write over each other.
2. I might check the way you're adding 'values' in the params - can you feed an object just like that? Does it have to be a certain datashape or something?
That's where I'd start looking into!
