Style Theme not working at runtime(TWX 9.1)
Hi
i am seeing changes as per Style theme in mashup at design time but when i view the mashup not getting Style theme . What would be the issue ? in Permission tab also i see that nothing is created and i use as Administrator.
can anyone help me?
c_lowyAnswer
Could you check if option UseTheme is enabled in the properties of the themeable widgets you have in your mashup ?
c_lowy16-PearlAnswer
Hi @VS_9760165 , Yeah known behaviour should work after removing child mashup container color.
