pshashipreetham
Style Themes are not working
I am using Style Theme for around 50 Mashups, but suddenly labels, font weight and family are not working.
When I open the Mashup in the runtime, in the console, I see the below errors:
@pshashipreetham can you share your Mashup xml file and tell the version of your thingworx instance?
pshashipreetham
Hi @wcui ,
Thanks for the response. Mashup.xml will have a lot of dependencies, so it can't be shared.
Thingworx Version: 9.3.0
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Sorry I wrongly clicked the "Accept as a Solution" button. Let's continue the investigation.
Did the issue suddenly happen? I mean is the style theme used to work normally? if yes, can you try a different browser or try clear cache?
besides, can you create a simple demo Mashup using the same style theme? if issue also reproduce there, please supply the demo entity and style theme.
