pshashipreetham
Jul 19, 2026 12:01 PM UTC
Styling issue with List Widget
I have a List widget placed as a menu on the Master. The issue is that when I hover over the selected List Item, it shows a white border around the label on all four sides.
Community Manager
Jul 22, 2026 3:43 PM UTC
Hi ​@pshashipreetham
You’re likely running into a Hover style. You may be able to remove the border in the widget’s Style Properties. Alternatively, if you are comfortable with applying custom CSS you may be able to disable or alter the styling with that (for an example see CS408027 How to change the hover style of checkbox on Grid widget on ThingWorx Platform). If you are using a Style Theme you may have to edit that instead.
To help further, please let the community know what version of ThingWorx you are using and what the expected behavior is. Additional information on the styling you are currently using would also be helpful, along with any other configuration for the default List Widget. You may also want to inspect the element in your browser’s developer tools to identify what part is causing the border.
Best regards, Nathaniel
Community Manager
Oct 7, 2026 7:17 PM UTC
Hello ​@pshashipreetham,
Did the response I gave resolve the issue you are facing? If not, please provide further information and context as requested so the community can better assist you.
