8-Gravel
Switch Visibility with togglebutton
I want to switch the visibility option from a label and a slider in a Mashup
When the button is in the "OFF" state I want the label to be visible and the slider to be invisible.
When the button enters the "ON" state I want the label to be invisible and the slider should be visible.
My current configuration makes it so I can toggle the visibility how I want it for the slider but now the label.
Is it possible to have two options for the state from the togglebutton (OFF and ON)? right know I can only set the "STATE" option but I cannot choose which state and what the output value etc should be...
I am using ThingWorx 9.1.0-b10877 if that matters.
Thank you
Best regards
Nicolas HORST
slangleyAnswer
Support
Hi @NHorst.
You could create 2 separate expressions in the Mashup - 1 for each widget to evaluate the current value and then switch it.  Here's a link to the Help Center for more information on expressions.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @NHorst.
--Sharon
NHorst8-GravelAuthor
8-Gravel
Hi @slangley ,
Thank you for your answer.
I will it with the expressions.
Best regards
Nicolas HORST
