Syntax of updating the property VTQ
To update the property VTQ on Thingworx platform using lua EMS is the following possible.
properties.propertyName={baseType="NUMBER", pushType="ALWAYS", value=0}
--To update on thingworx
local variableName = propertyName
properties.variableName.value = <someValue>
I tried it in different ways but it's giving me an error.
Thank You,
Naeem
mnaeemAnswer
Hi @slangley ,
Unfortunately I'm unable to find the solution and I've changed the way reading reading csv file on Thingworx platform instead of through agent.
Copying the file from agent to the server and then reading it on server.
It was the fastest way.
Thank You,
naeem
22-Sapphire I
You can use this service:
UpdatePropertyValues
mnaeem1-VisitorAuthor
Thank You @PaiChung
properties.Signal_Q30={baseType="NUMBER", pushType="ALWAYS", value=0}
serviceDefinitions.GetSystemProperties(
     output { baseType="BOOLEAN", description="" },
     description { "updates properties" }
services.GetSystemProperties = function(me, headers, query, data)
     log.trace("[TemplateRilevatore]","########### in GetSystemProperties#############")
     queryHardware()
     -- if properties are successfully updated, return HTTP 200 code with a true service return value
     return 200, true
end
function queryHardware()
     nome = "Signal_Q30"
     valore = 2
     serviceName(nome, valore)
end
I'd like to call a service in place of serviceName, which has been written on thingworx platform.
Thank you!
22-Sapphire I
You are looking to do this from an agent?
Usually you would use 'UpdateSubscribedProperties' for that.
Thank You @Chandler1 ,
I'm talking about calling services of Thingworx in agent (LUA EMS).
For example:
     queryHardware()
     return 200, true
end
     name = "Signal_Q30"
     value = 2
     UpdatePropertyValue(name, value) --Service on Thingworx platform
end
Support
Hi @mnaeem.
I realize that you've already marked a solution to this post, but since a couple of replies have since been received, I want to be sure you don't have any remaining questions.  Please let us know.
--Sharon
mnaeem1-VisitorAuthorAnswer
Hi @slangley ,
Thank You,
naeem
