Tabs widget
Thingworx 8.5.2 :
I see white space for each tab even after applying background color through properties.is there any way to achive it using css.If so,please let me know as I tried and couldn't achieve it.Please check the snip below.
I tried using developer tools and able to achieve over there.But how do I implement the same using custom css in Thingworx.Help me with the code.Please see the attached file
krishnakomal1-VisitorAuthorAnswer
Hi , Just make the margin to zero in the css class of the tab.
