Jul 2, 2019 11:55 AM UTC
tabsequence - tabbing between widgets
The tabsequence property on widgets seems obvious, but for some reason, I have been unable to get the tabbing order correct.   I also can find zero documentation that explains the syntax short of it indicating it's the sequence of tab order.   I have taken widgets and numbered them sequentially, but the tab order ( tab key ) does not seem to work.
Any suggestions would be appreciated.
posipovaAnswer
20-Turquoise
Jul 18, 2019 2:09 PM UTC
For your reference, Jira PSPT-7306 has been reported.  I will close this thread for now and will update you once there is any status change.
(I may have given you the wrong, internal number in the chat).
20-Turquoise
Jul 2, 2019 1:14 PM UTC
What is your ThingWorx platform version and the browser you are using?
KentV1-VisitorAuthor
Jul 2, 2019 1:15 PM UTC
We are on Thingworx 8.4 and I'm using Chrome Version 75.0.3770.100 (Official Build) (64-bit).   All running on a Mac Book Pro.
Thanks in advance.
-- Kent
20-Turquoise
Jul 2, 2019 2:45 PM UTC
To clarify, are you trying to use hot keys to tab?
