TCP/IP Connectivity to Thingworx
I need to connect to a device using TCP/IP connection. Have got the Ip and Port for the TCP. Is there any extension available to pull the data.
I have also tried to use WebSocketsTunnelWidgetAndLibrary3.0.1. But its not getting connected. Have made changes in the Configuration column.
Please suggest.
Saddam
Hello Saddam,
Can you please further describe the device itself and what information we are looking to gather off of it? If the device can accept WebSocket connections then ThingWorx should be able to form this connection.
There used to be an extension available in the Marketplace to at least send data via TCP message.  I included the original extension and the PDF manual.  For whatever reason, this was removed.  We've been using this extension for some time with good results.
Currently the TCP Extension has been removed from the PTC Marketplace. As it is a Labs extension it is not directly supported by PTC Technical Support.
If you could provide some further information on your use case and the data we are hoping to exchange between Platform and Device via the TCP/IP connection I can look further into potential alternatives.
shussain11-VisitorAuthor
I have a device/PLC which supports only TCP/IP. from which i have to take data to TWX platform.
Can't use any other softwares like Kepware. So have to pull data to TWX using the TCP/IP from the Device/PLC.
