adiku3-NewcomerAuthor
3-Newcomer
In short, I need to implement text to speech.
18-Opal
The solution depends on your operating system, but the general approach would be to create a Java extension and either use some Java library for TTS, or execute some command line.
/ Constantine
3-Newcomer
@Constantine Thanks for the reply. But how to execute the powershell or command line using the service of Thingworx
