PaiChungAnswer
22-Sapphire I
If you use the upload widget or the filetransfer copy function, there will be a completed event you can use.
if you don't have those, then you'll have to do some sort off 'file watcher setup' where a timer or scheduler check the folder
OR if the system that is sending the file has the capability, it could invoke a rest api call
PaiChung22-Sapphire IAnswer
22-Sapphire I
and113-AquamarineAuthor
thanks a lot for your reply!
