The following widget failed to load : Mashup
Hi all,
Whenever I try to open mashup I'm getting the below warning,
Will this cause any issue with UI?
/ VR
Hello @Velkumar ,
Try to clear the browser cache and then reloading the Mashup.
Let me know if it works for you.
Regards
Bhawna
Velkumar19-TanzaniteAuthor
No it didn't solve the issue
I have also started receiving these warnings since updating to TWX 9.3.
Is this the version you are using as well? I have not found any way to get rid of these warnings although I have also not seen any issues with any mashups that have had them.
Yes, we are also using 9.3.
