11-Garnet
Jul 12, 2024 12:45 PM UTC
The Relationship Subsystem must be enabled
I get following error when I want to search for a referenced service :
"The Relationship Subsystem must be enabled, configured, and running to view references. You can manage this from the RelationshipSubsystem.".
When I go to the "Subsystem:RelationshipSubsystem" it's already enabled because for other entities(things) it works.
Any idea what can be the problem ?
Izzet
Jul 13, 2024 12:25 PM UTC
11-Garnet
Jul 15, 2024 9:45 AM UTC
Hi @VladimirN ,
the referenced by feature is already enabled, because for other services the reference is working but for this 1 service not. Still gives the message to enable it when clicked on reference by.
Jul 15, 2024 10:21 AM UTC
Hi @IB_9961693 ,
1. How exactly are you searching for a service reference by clicking on "Reference by"?
That tab is available only at the Thing level, and lists all the references for that Thing, regardless of characteristics (eg: it does include services at this level).
Maybe you're referring to a Thing and by mistake you mentioned "service" ?
2. Disable, Save, then Enable and Save back the Relationship subsystem. If this issue manifests again, please open a Support Ticket.
