There is no click on a portion of Pie Chart, there is no output saying with part is selected
I have implemented pie chart in my mashup. I need to get pop up with information related to the portion selected.
In properties of pie chart I have observed that
1. There is no single click event in pie chart i.e, Only Double-click available.
2. There is no option to fetch which portion has been selected.
3. There is only tool tip available which will show the value, but no option to display value on the text.
Please let me know, Anyone know how to implement feature which will display the data related to the portion of pie chart selected and to display value on the potion of pie chart.
22-Sapphire I
You will have to custom add that, basically create a custom widget extension.
22-Sapphire I
I got this from a co-worker which might do what you need, hope the attachment works.
BhavyaPC1-VisitorAuthor
@PaiChung
Thank you .., But I feel D3PieChart widget is not supporting. I didn't get output, It's blank.
Any other solution...??
As stated above developing custom widget will be a solution in this case .
Mukul Narang
