Oct 7, 2020 2:47 AM UTC
Thing is not enabled even though EnableThing/RestartThing is called
I am trying to create a DataTable from a service.
try {
 var thingParams = {
 description: undefined /* STRING */,
 thingTemplateName: "DataTable" /* THINGTEMPLATENAME */,
 tags: undefined /* TAGS */
 // no return
 Resources["EntityServices"].CreateThing(thingParams);
 Things["MyDataTable"].EnableThing();
 Things["MyDataTable"].RestartThing();
 Things["MyDataTable"].SetProjectName({ projectName: "MyProject" });
 Things["MyDataTable"].SetDataShape({ name: "MyDataShape" });
} catch (err) {
 logger.error(me.name + " Service DataTableHelper.WriteToDataTable has an error on line #" + err.lineNumber + ": " + err.message);
I get the foolowing error:
DemoFileHelper Service DataTableHelper.WriteToDataTable has an error on line #14: com.thingworx.common.exceptions.InvalidRequestException: Thing [MyDataTable] is not enabled
Line 14 is the one where I set the Project Name.
Any help would be welcomed.
Oct 7, 2020 1:14 PM UTC
I have moved the setDataShape declaration a bit higher and it seemed to work. (changed the datashape and project name with something on my system).
try {
 var thingParams = {
 // no return
	name: "ad" /* DATASHAPENAME */
 Things["MyDataTable"].SetProjectName({ projectName: "GitBackup" });
} catch (err) {
try {
 var thingParams = {
 // no return
} catch (err) {
cmelancon1-VisitorAuthor
Oct 7, 2020 2:52 PM UTC
Thank you, it worked!
