Thing is not running - SQL JDBC
I try to connect a Microsoft SQL Database to ThingWorx … I installed the JDBC MSSQL Connector Extension from the Marketplace and imported it … Then I created a Thing “DB1” with the Base Thing Template MSSqlServer… In the Configuration page I tried to configured…
JDBC Driver Class Name:
com.microsoft.sqlserver.jdbc.SQLServerDriver
JDBC Connection String:
jdbc:sqlserver://127.0.0.1\SQLEXPRESS;databaseName=thingworx
connectionValidationString:
SELECT GETDATE()
Database User Name:
sa
Database Password:
my password
after saving I get the Message Thing[DB1] is not running…
can anybody help me?
I use..
Thingworx:8 trial
Microsoft SQL Server 2017
best regards!
posipovaAnswer
20-Turquoise
I'm suspecting the extension might have not been updated in a while and the driver supplied is old.
Could you please  take a look at my response to this thread (first comment) for detailed instructions on how to package a new jdbc driver?
https://community.ptc.com/t5/ThingWorx-Developers/Using-a-third-party-Jar-file-for-Database-connection/m-p/514861
20-Turquoise
It seems the db connection is not getting established. Do you have all the needed ports enabled in your SQL database? Check ThingWorx application log for errors.
GrafZahl1-VisitorAuthor
In the ThingWorx  application log is the following message:
ERROR starting: JDBC Driver Class Not Found: com.microsoft.sqlserver.jdbc.SQLServerDriver
Error message: Thing is not running
in my SQL Management Studio my instance port 1433 is enabled.
- the Windows Firewall is off.
- FYI my Windows Server 2017 is a VM Ware.
20-Turquoise
Do you have TCP/IP enabled in your SQL configuration manager?
