Thing property values became empty and quality is showing unknown.
Thing properties became empty when I'm checking property vtq, it's showing unknown.
These properties are updating from last two weeks but from yesterday it's showing empty values.
Why values are getting empty and why the property quality is unknown?
On what basis property quality is calculated? Did anyone faced this issue?
Can anyone help me with this issue?
Abhiram Kuncham
22-Sapphire I
Did the Thing become disconnected or did you change the model and the values become null?
Abhiram10-MarbleAuthor
Thank you for your response PaiChung.
No, thing is having properties which inherit from thingshape and some of those properties are binded to remote thing. Properties which are binded are having proper values remaining property values became empty.
Model and all remains same, nothing was changed.
when I check property vtq, quality of some properties are showing UNKNOWN.
What is this unknown means and how the quality is checked.
22-Sapphire I
Usually Unknown means the value is null, not received/outdated, or never set.
