Thingworx 8.1 - Not starting
I having Thingworx 8.1 with H2 Persistence Provider. While try to launch TWX, Tomcat itself not loading. In Application log, i am getting an info like "HA mode not enabled. Initializing and starting in standalone mode." .
How can i resolve this?
Thanks for your response.
I think this issue was related with DB. I just replaced the H2Backup file. Now it is working fine.
Once again thanks for your kind reply.
Hi @Sathishkumar_C,
This is not the error, it is only INFO which is not the actual cause of ThingWorx not starting.
Please check the application logs and check for errors which is causing the issue.
Also make sure you have proper license file installed, all the tomcat configurations (java options) are correct and compatible software - JDK/Tomcat are installed on your machine.
If still you are unable to resolve the issue, please share the application logs.
We will have a look on that to find the cause.
Himanshu
Please find attached Tomcat log file
Hi Sathish,
Please do check the if the JavaOptions in the Java tab of the Configure Tomcat is correct.
For example :  "-Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEB-INF\extensions", check if this path exist in your system. This might also be a reason for the tomcat not being able to start.
Regards
Saran
