Feb 6, 2018 9:38 AM UTC
Thingworx 8.2 deactivation and licence transfer
I need to activate on premise demo with available Thingworx 8.2 offline site licence (Licensing Guide for disconnected sites). Can this licence be safely and easily removed afterwards and transferred to production environment?
Thanks JG.
Feb 27, 2018 8:31 AM UTC
Hi @jgabriel i think this should be possible when doing offline installation since there as far as i know you will have to enter the device id manually to fetch the license capability file. So you could probably use that to switch your licenses between the instances. Have you already tried this?
jgabriel1-VisitorAuthor
Feb 27, 2018 8:36 AM UTC
I did offline licence installation and it went fine. But I am not sure how to deactivate or if that is necessity...
Feb 27, 2018 8:45 AM UTC
My understanding is that once you have downloaded (activated licensed features on 1 device ID) it will only work for that 1 device ID - all previous Device ID would not be valid/active anymore. Let us know if you are seeing otherwise, in that case it may need further investigation.
