Thingworx 8.4 not started in my local tomcat
1. i'm using Amazon -Virtual Desktop system -Windows 10 , i doesn't have admin rights of my Virtual Desktop system and installed the JDK 1.8 -64 but and Tomcat 9 and Postgresql 9.6 .
2. ThinkworxPlatform and ThingworxStorage folder given full right of read and write
3. Deployed Thingworx war into Tomcat .
4. While startup the Tomcat facing the below error .
5. ThingworxStorage folder inside LOGS folder not created any logs.
Please kindly help to resolve my issues ASAP, Thanks in Advance.
NOTE:  i followed  below thread solution but not worked out me.
https://www.ptc.com/en/support/article?n=CS305796&language=en&posno=1&q=Caused%20by%3A%20java.lang.RuntimeException%3A%20Failed%20to%20create%20SecurityManager%2C%20Failed%20to%20load%20SecretProvider&source=search
ERROR DETAILS:
03-Nov-2019 18:44:54.329 SEVERE [main] org.apache.catalina.core.StandardContext.filterStart Exception starting filter [HAAuthenticationFilter]
javax.servlet.ServletException: com.thingworx.exceptions.ConfigurationException: java.lang.RuntimeException: Failed to create SecurityManager, Failed to load SecretProvider
at com.thingworx.security.authentication.HAAuthenticationFilter.init(HAAuthenticationFilter.java:49)
at org.apache.catalina.core.ApplicationFilterConfig.initFilter(ApplicationFilterConfig.java:270)
at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:251)
at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:102)
at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4533)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5172)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:717)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:978)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1849)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:112)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:773)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:427)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1576)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:936)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:841)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1384)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1374)
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:134)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:909)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:421)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:930)
at org.apache.catalina.startup.Catalina.start(Catalina.java:633)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:344)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:475)
Caused by: com.thingworx.exceptions.ConfigurationException: java.lang.RuntimeException: Failed to create SecurityManager, Failed to load SecretProvider
at com.thingworx.system.configuration.PlatformSettings.getInstance(PlatformSettings.java:1682)
at com.thingworx.security.authentication.HAAuthenticationFilter.init(HAAuthenticationFilter.java:36)
... 44 more
Caused by: java.lang.RuntimeException: Failed to create SecurityManager, Failed to load SecretProvider
at com.thingworx.security.SecurityManagerBootstrapper.init(SecurityManagerBootstrapper.java:65)
at com.thingworx.system.configuration.PlatformSettings.<init>(PlatformSettings.java:1057)
at com.thingworx.system.configuration.PlatformSettings.getInstance(PlatformSettings.java:1673)
... 45 more
03-Nov-2019 18:44:54.682 SEVERE [main] org.apache.catalina.core.StandardContext.listenerStop Exception sending context destroyed event to listener instance of class [com.thingworx.system.ThingWorxBootstrapper]
java.lang.NullPointerException
at com.thingworx.system.ThingWorxBootstrapper.contextDestroyed(ThingWorxBootstrapper.java:311)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4732)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5396)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:257)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:187)
03-Nov-2019 18:44:56.259 INFO [main] org.apache.catalina.core.ApplicationContext.log ContextListener: contextInitialized()
03-Nov-2019 18:44:56.260 INFO [main] org.apache.catalina.core.ApplicationContext.log SessionListener: contextInitialized()
03-Nov-2019 18:44:56.262 INFO [main] org.apache.catalina.core.ApplicationContext.log ContextListener: attributeAdded('StockTicker', 'async.Stockticker@6536f06c')
03-Nov-2019 18:45:00.938 INFO [Thread-4] org.apache.catalina.core.ApplicationContext.log SessionListener: contextDestroyed()
03-Nov-2019 18:45:00.938 INFO [Thread-4] org.apache.catalina.core.ApplicationContext.log ContextListener: contextDestroyed()
03-Nov-2019 18:46:05.598 INFO [main] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
Support
Hi @karthik24.
You said you don't have Admin rights, correct?  If so, did you run into any issues installing Java, PostgreSQL, and Tomcat?  Where did you create the \ThingworxStorage and \ThingworxPlatform folders?
--Sharon
karthik241-VisitorAuthor
Thanks lot taking time to reply, yes, i doesn't have admin rights and able  created ThingworxStorage and \ThingworxPlatform folders and no issues for while install the Java,tomcat,PostgreSQL.
20-Turquoise
Seems like it either cannot find ThingworxPlatform folder or the tomcat used doesn't have sufficient permissions (more likely). Make sure your tomcat user is granted full access to:
C:\ThingworxBackupStorage
C:\ThingworxPlatform
C:\ThingworxPostgresqlStorage (or MSSQL)
C:\ThingworxStorage
C:\Program Files\Apache Software Foundation\Tomcat 9
Ensure the same user is to be used to start tomcat in system services.
Support
Hi @karthik24.
Please let us know if you have resolved your issue.  If you are still struggling, it's recommended that someone with Administrator rights perform the installation.
--Sharon
