Aug 28, 2019 6:51 PM UTC
Thingworx 8.4 Trial Warning: Problem running post-install step. Installation may not complete Ubuntu
- 10 replies
- 5585 views
- Translate All
Following the steps in this guide I was able to get the installer to run, but it's failing. Error message is not of much help. Following some forum recommendations I uninstalled and reinstalled the OS. i.e. new VM. Running Ubuntu 18.04 on an Azure F4 VM.
It appears to be similar to this unsolved windows 7 issue, which was asking for some logs, I attached the install.log in case that is relevant
Any thoughts on what to try next?
---------------------------------------------------------------------------- Configuration Summary Review and confirm the following configuration settings: Installation directory: /opt/ThingWorxH2Trial-8.4.0-SNAPSHOT Local ThingWorx port: 8080 Local ThingWorx SSL port: 443 Minimum Java heap size for ThingWorx: 1024 Maximum Java heap size for ThingWorx: 2048 Press [Enter] to continue: ---------------------------------------------------------------------------- Setup is ready to install ThingWorx Trial for H2. Do you want to continue? [Y/n]: Y ---------------------------------------------------------------------------- Setup is installing ThingWorx Trial for H2. This might take a few minutes. 0% ______________ 50% ______________ 100% ########################################Warning: Problem running post-install step. Installation may not complete correctly Error running ./check-http-response --username "Administrator" --password **** --hostname "localhost" --hostport "443" --useSSL=1: 1 Press [Enter] to continue: Warning: Problem running post-install step. Installation may not complete correctly Error occured while running postInstall Validation scripts Press [Enter] to continue: # ---------------------------------------------------------------------------- ThingWorx Trial for H2 installation failed. Error: There has been an error. Error occured while running postInstall Validation scripts Press [Enter] to continue:
