ThingWorx 8.5 Style Themes
When creating and using a Style Theme I have the option to select fonts on different items (Headers, Labels, Body)
There are several fonts as standard, but how do I use for instance the Roboto opensource font?
In 8.3 I put the font in a repository and used CSS to specify on a top level to use this font with !important
Not a good way...
Can I "install" a font and use it in Style Themes?
22-Sapphire I
You can still call out font styles using CSS either at the top level or on mashup level and I think you can still assign it to a widget.
@rogerjn  If the previous response resolved your issue then, please post it here and mark it as the Accepted Solution for the benefit of others on the community.  If you are still experiencing issues, please do let us know your questions or concerns.
Vibhuti
