7-Bedrock
ThingWorx 8 install on the Linux
- 4 replies
- 2775 views
- Translate All
Hi all,
I follow the document to intall ThingWorx 8 on the RedHat
But I can't success to startup tomcat service.
When I start tomcat service. It will say 'ExecStart=/usr/share/tomcat8.5/bin/jsvc ....' error
Does anyone has install success on RedHat? Please help me.
Thanks.
[Unit]
Description=Apache Tomcat Web Application Container
After=network.target
[Service]
Type=forking
PIDFile=/var/run/tomcat.pid
Environment=CATALINA_PID=/var/run/tomcat.pid
Environment=JAVA_HOME=/usr/lib/jvm/jdk1.8.0_92
Environment=CATALINA_HOME=/usr/share/tomcat8.5/8.5.13
Environment=CATALINA_BASE=/usr/share/tomcat8.5/8.5.13
Environment=CATALINA_OPTS=
ExecStart=/usr/share/tomcat8.5/8.5.13/bin/jsvc \
-Dcatalina.home=${CATALINA_HOME} \
-Dcatalina.base=${CATALINA_BASE} \
-Djava.awt.headless=true -
Djava.net.preferIPv4Stack=true -Dserver -Dd64 -XX:+UseNUMA \
-XX:+UseConcMarkSweepGC -Dfile.encoding=UTF-8 \
Djava.library.path=${CATALINA_BASE}/webapps/Thingworx/WEB-INF/extensions \
-cp ${CATALINA_HOME}/bin/commonsdaemon.jar:${CATALINA_HOME}/bin/bootstrap.jar:${CATALINA_HOME}/bin/tomcatjuli.jar
-user tomcat8.5 \
-java-home ${JAVA_HOME} \
-pidfile /var/run/tomcat.pid \
-errfile ${CATALINA_HOME}/logs/catalina.out \
-outfile ${CATALINA_HOME}/logs/catalina.out \
$CATALINA_OPTS \
org.apache.catalina.startup.Bootstrap
[Install]
WantedBy=multi-user.target
