Thingworx 9.1 adjust width of label text on value display
  • May 11, 2022
  • 5 replies
  • 2196 views
Hi! I have a large value display that is cutting off the label text at the top.  The widget is definitely wide enough but the text is not the length of the value display.  How do I extend it instead of it showing the ellipses(...)?
Best answer by blacksheep
I already changed the value display widget to a label widget and now it shows all the text.
Is this in a custom app/mashup? The OOTB Navigate apps or LandingPage mashup are not editable.
Yes it is a custom app.
Support
May 18, 2022
Hi @blacksheep
Can you send us the mashup to see if we can reproduce it?  We weren't able to recreate it in our testing.  You can remove any sensitive information.
--Sharon
blacksheep1-VisitorAuthorAnswer
Support
June 3, 2022
Hi @blacksheep.
I have marked the solution to your post.  If you disagree with my choice, please let me know.
--Sharon
