7-Bedrock
Thingworx 9.2.5: Failed to load FlxCore
Hi, I'm getting the same issue. I´m using this image Tomcat9
Is there any update to solve this issue?
Support
Hi @lsanchezm
Please provide details of the error you're getting and your configuration.  If you actually are seeing the "Failed to load FlxCore" error, I'm afraid you will need to refer to the Help Center for the relevant version of ThingWorx for supported configurations.
--Sharon
Hello @lsanchezm
Can you please share the errors you are getting ? so that we can suggest you next action items here
Hello  @lsanchezm
You can also refer following articles which might be helpful here
https://www.ptc.com/en/support/article/CS259533?source=search
https://www.ptc.com/en/support/article/CS355642?source=search
