Thingworx 9.2 - Tab Widget Configuration - Tab Height
We are using a tab widget in Thingworx 9.2.
It seems we can't reduce "Tab Height" which is available in Thingworx 8.5.
Is there any alternative for this?
sathish
Support
Hi @Sathishkumar_C,
You can select the Tab Widget, Navigate to Style Properties > Base > Tab > height to adjust the Tab Height as needed.
Yes, That's okay.
But it seems, only the label size is changing. The Tab header height not changing.
Support
Hi @Sathishkumar_C,
That's weird. I tested in my 9.2.1 environment, specifying the height only changes the Tab height, doesn't change the label size at all...
Could you please provide entities and screenshots?
