thingworx 9.2 timezone
In the latest release of ThingWorx 9.2, is the timezone issue resolved? In the previous versions the time would always show the local system time instead of time in which the application is installed. Is that issue resolved?
Thanks in advance,
Shalini V.
Article - "[Important] New Required Timezone setting in ThingWorx 9.x": https://www.ptc.com/en/support/article/CS331340
Support
Hi @svisveswaraiya_285745.
Can you advise what issue you're experiencing?  The time is meant to be stored as UTC to ensure the time is reflected accurately at the client.
What is the server time vs. local time?  Which do you expect to see?
--Sharon
