7-Bedrock
Jul 9, 2026 10:13 AM UTC
ThingWorx 9.3 - Timer Things and Schedulers Not Triggering in One Environment Only
We are facing an issue in our ThingWorx 9.3 Production environment where Timer Things and Schedulers are not executing, while the same configuration works correctly in other environments.
Environment
  • ThingWorx Version: 9.3
  • License: Valid until 2027
  • Issue specific to production environment
Validation Performed
  • Verified Timer Thing is enabled.
  • Verified runAsUser is set to Administrator.
  • Verified subscriptions are enabled.
  • Compared Timer Thing XML/configuration between working (test) and non-working (production) environments; no significant differences found.
  • Created a new test Timer Thing with a simple logging subscription; it did not trigger.
  • Created a test Scheduler; it also did not execute.
  • Restarted the ThingWorx server.
  • Verified license status through Licensing Subsystem.
Rocko
RockoAnswer
Jul 9, 2026 11:42 AM UTC
Timers need not only to be “enabled” from a thing lifecycle perspective, they also need to be enabled in a sense of triggering. run the IsEnabled service to check, if not already. Check timezone setting of machine and TWX server.
Increase logging and check log file. Check articles
https://www.ptc.com/en/support/article/CS415845 (log settings)
https://www.ptc.com/en/support/article/CS285274
https://www.ptc.com/en/support/article/CS439101
https://www.ptc.com/en/support/article/CS435365
Rocko
Rocko19-TanzaniteAnswer
Jul 9, 2026 1:56 PM UTC
Can you check in ApplicationLog for logs regarding your timer and scheduler name? It might complain what’s wrong with it
Jul 15, 2026 11:59 AM UTC
You may check if System user has service execute permissions on Things, it happens sometimes.
Support
Jul 17, 2026 3:46 PM UTC
Hi ​@AC_10460579,
I hope you are doing well!
I wanted to follow up and see if you've had a chance to review the suggestions provided by the community members. If any of the responses helped resolve your issue, please consider marking the appropriate reply as the Best Answer so it can help others with a similar question.
If the suggestions did not resolve the issue, please let the community know by sharing an update or any additional details.
Thank you!
Abhi
