Thingworx 9.5 - SetPlatformSessionTimeout
I had try to disable timeout session by enter 0 in value ..... ( SetPlatformSessionTimeout service in User Management Subsystem )
But  now, I loose access in Composer and Runtime  😞
Who I can reset 30 minutes ?
PRoparsAnswer
I succeeded to restore default value by editing SQL database :
Go to your SQL database, edit table subsystem_model, select 'User Management' line in description ;
Edit JSON data in configurationTables field and restore 30.0 in timeout object
...."description":"Session Management Settings","rows":[{"userServiceSelfBypass":true,"restrictConcurrentUserSessions":false,"timeout":30.0}].....
PRopars10-MarbleAuthorAnswer
Hello @PRopars ,
Kindly mark your respose as solution for the benefit of other community users.
Thank you
Bhawna
