3-Newcomer
May 14, 2025 12:09 PM UTC
ThingWorx 9.6.3 – How to Bulk Edit Properties After Binding Tags?
I'm using ThingWorx 9.6.3 and adding tags to a Thing using the Manage Bindings feature. The properties get added as read-only by default and are not set to be persistent or logged.
Is there a way to bulk edit these properties after binding them to enable persistence, logging, and set the appropriate dataChangeType (like ALWAYS or VALUE)? I don't see any bulk edit option in the UI.
Any suggestions on how to handle this efficiently would be really helpful.
Rocko
RockoAnswer
May 14, 2025 12:31 PM UTC
Option 1) Use API
Option 2) Export Entity to XML, change in XML, reimport.
Rocko
Rocko19-TanzaniteAnswer
Option 1) Use API
3-Newcomer
May 19, 2025 6:39 AM UTC
Can you elaborate on the first option.
Rocko
May 19, 2025 7:15 AM UTC
Depending on what you want to do, you could e.g. run SetPropertyLogging on your entity to enable logging. If you do that in a loop you can do that for all properties in one go. For other options there is no such API and you would have to remove and re-add the property using
GetPropertyDefinition, RemovePropertyDefinition and AddPropertyDefinition. There are similar services for bindings.
