ThingWorx Analytics Trial - Lose connection to AnalyticsBuilder, Docker cont. twxfoundation stops
- 7 replies
- 3372 views
- Translate All
Hello all!
If I follow the learning "Build a Predictive Analytics Model" (https://developer.thingworx.com/resources/guides/analytics-builder-quickstart/analytics-builder-setup)
First problem is that the binding of the data "analytics vibration" does not go over the progress ... status.
So after i while i click cancel, because nothing happens. Nevertheless i see the data then with status "completed". Then i go on to "Signals" an follow the steps. I can see the different sensor names s1_fb1 ... but no values on the right. It´s not loading. At this point im loosing every time the connection to thingworxbuilder and also to composer.
The builder does not react any more if i switch for example to settings...
Status message:
Could not load "TW_ML_Signals_Horizontal_v1". Reason: 200 -
If i check docker container ls status i see that twxfoundation is not there anymore. I need to restart TWA but i can not go further than the problem described above in the "Signal " configuration...
Please find the logs
- Docker Service log
- Status / Debug AnalyticsBuilder
- Status messages snap
Thank you very much
