Mar 6, 2017 2:24 AM UTC
Thingworx and EMS
     Hi,everyboby.I have completed the Raspberry Pi Quickstart documentation.
     I'm able to use EMS to send raspberry voltage and other data uploaded to the thingworx platform.   Now I want to read the data on the sensor that placed on the raspberry through use of EMS,and then  will be the sensor data uploaded to the Thingworx platform .
Can you recommend several learning documents or examples?
Thanks!
Mar 6, 2017 8:01 AM UTC
Hi Wang, reading data from the sensor won't be that complicated it would require you to use the library for that sensor which if you don't have it already you will have to search/Google it and using that library you'll gather the data and push it to ThingWorx. For e.g. i used the REST API together with Python to deliver the payload but you can do the same with EMS, below code collected and pushed the data every 5 seconds from the sensor and then to the ThingWorx.
#!/usr/bin/python
import sys
import time
import json
import logging
import requests
import Adafruit_DHT
# enabling the logging
try:
    import http.client as http_client
except ImportError:
    #Python2
    import httplib as http_client
http_client.HTTPConnection.debuglevel=1
# defining the sensor type and the pin on which the data needs to be collected
sensor = 11
pin = 4
var = 1
#Webserver URL in TW
Webhost = "http://tw713:8080/Thingworx/Things/TempAndHumThing/Properties/*"
App_Key = "<appKey>"
while var == 1:
hum, temp = Adafruit_DHT.read_retry(sensor, pin)
print('Temp={0:0.1f} *C  Hum={1:0.1f}%'.format(temp, hum))
#ThingName = "TempAndHumThing"
headers = {'Content-Type': 'application/json', 'appKey': App_Key}
payload = {'temp': temp, 'hum': hum}
response = requests.put(Webhost, headers=headers,json=payload, verify=True)
time.sleep(5) # sleep for 5 seconds
There's another great reference/guide you could use from one of the community Blog post Using the C SDK to Deliver Data to ThingWorx from a Raspberry PI
Hope this would help.
wwang-211-VisitorAuthor
Mar 7, 2017 9:08 AM UTC
Hi,Sushant
    Thanks for your help!
    I want to send the data of the read sensor to the thingworx platform via EMS this connection.Can I use lua to read sensor data? Now I have speed sensors, ultrasonic sensors and so on. I want to measure the displacement of the ultrasonic sensor through the EMS upload to the platform for observation.What language is used to read the data on the sensor is better? And then in the Template folder under the Template.lua set properties and services.
Mar 6, 2017 10:44 AM UTC
Hi Wang,
Using the Sense HAT is not limited or specific to Thingworx, basically once you have your Pi and Sense HAT hooked and configured you could use the Sense HAT from anywhere using the existing APIs to read/write to/from it. The Thingworx tutorial on getting the basic information from the Raspberry Pi (i.e. CPU freq&temp) which you've already mentioned as having done successfully can be expanded to read Sense HAT specific sensor information. The key idea is that you can call from your Pi LUA script, i.e. a PiTemplate.lua script to read basic Pi information, other Python scripts that read sensor data from the Sense HAT and then supply thier results back to set Thingworx thing properties values. You can also send from Thingworx strings to be displayed on the Sense HAT LED matrix by defining a remote service on the Pi thing and call it with the string to be displayed. The most common operation however would be to read the Sense HAT's sensor data such as  position, humidity and pressure. I have used these resources to learn about reading the Sense HAT sensor data:
https://www.raspberrypi.org/learning/getting-started-with-the-sense-hat/
there is also a specific Astro Pi related page you can refer to:
https://astro-pi.org/get-involved/program-the-sense-hat/python/
There is of course a fully fledged API documentation page available for the Sense HAT:
https://pythonhosted.org/sense-hat/
What I found most useful were the examples from the getting started with the sense hat. I started from the existing LUA example.lua template and built a Pi specific one to include services and properties to read Sense HAT sensor data.
Just as an example, my PiTemplate.lua script looks like this:
module ("templates.PiTemplate", thingworx.template.extend)
properties.cpu_temperature  =     { baseType="NUMBER",  pushType="ALWAYS", value=0 }
properties.cpu_freq  =     { baseType="NUMBER",  pushType="ALWAYS", value=0 }
properties.cpu_volt  =     { baseType="NUMBER",  pushType="ALWAYS", value=0 }
properties.temperature = {baseType="NUMBER", pushType="ALWAYS", value=0}
properties.pressure = {baseType="NUMBER", pushType="ALWAYS", value=0}
properties.humidity = {baseType="NUMBER", pushType="ALWAYS", value=0}
properties.yaw = {baseType="NUMBER", pushType="ALWAYS", value=0}
properties.roll = {baseType="NUMBER", pushType="ALWAYS", value=0}
properties.pitch = {baseType="NUMBER", pushType="ALWAYS", value=0}
serviceDefinitions.GetSystemProperties(
output { baseType="BOOLEAN", description="" },
description { "updates properties" }
services.GetSystemProperties = function(me, headers, query, data)
log.trace("[PiTemplate]","########### in GetSystemProperties#############")
queryHardware()
queryOrientation()
queryEnvirons()
return 200, true
end
function queryOrientation()
local f = io.popen("python /home/pi/twx/microserver/etc/custom/templates/get_pitch.py")
local s = f:read("*a")
properties.pitch.value = s
f:close()
log.debug("[PiTemplate]", string.format("Pitch: %.2f", properties.pitch.value))
local f = io.popen("python etc/custom/templates/get_roll.py")
properties.roll.value = s
f:close()
log.debug("[PiTemplate]", string.format("Roll: %.2f", properties.roll.value))
local f = io.popen("python etc/custom/templates/get_yaw.py")
properties.yaw.value = s
f:close()
log.debug("[PiTemplate]", string.format("Yaw: %.2f", properties.yaw.value))
end
function queryEnvirons()
local f = io.popen("python etc/custom/templates/get_humidity.py")
properties.humidity.value = s
f:close()
log.debug("[PiTemplate]", string.format("Humidity: %5.2f", properties.humidity.value))
local f = io.popen("python etc/custom/templates/get_pressure.py")
properties.pressure.value = s
f:close()
log.debug("[PiTemplate]", string.format("Pressure: %6.1f", properties.pressure.value))
local f = io.popen("python etc/custom/templates/get_temperature.py")
properties.temperature.value = s
f:close()
log.debug("[PiTemplate]", string.format("Temperature: %4.1f", properties.temperature.value))
end
function queryHardware()
local tempCmd = io.popen("vcgencmd measure_temp")
local freqCmd = io.popen("vcgencmd measure_clock arm")
local voltCmd = io.popen("vcgencmd measure_volts core")
local s = tempCmd:read("*a")
s = string.match(s,"temp=(%d+\.%d+)");
log.debug("[PiTemplate]",string.format("temp %.1f",s))
properties.cpu_temperature.value = s
s = freqCmd:read("*a")
log.debug("[PiTemplate]",string.format("raw freq %s",s))
s = string.match(s,"frequency%(45%)=(%d+)");
s = s/1000000
log.debug("[PiTemplate]",string.format("scaled freq %d",s))
properties.cpu_freq.value = s
s = voltCmd:read("*a")
log.debug("[PiTemplate]",string.format("raw volts %s", s))
s = string.match(s,"volt=(%d+\.%d+)");
log.debug("[PiTemplate]",string.format("scaled volts %.1f", s))
properties.cpu_volt.value = s
end
tasks.refreshProperties = function(me)
log.trace("[PiTemplate]","~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ In tasks.refreshProperties~~~~~~~~~~~~~ ")
queryHardware()
queryOrientation()
queryEnvirons()
end
The python scripts for doing the actual reading look like this example:
def get_pitch():
    from sense_hat import SenseHat
    sense = SenseHat()
    sense.clear()
    o = sense.get_orientation()
    pitch = round(o["pitch"],1)
    return pitch
print("{0}". format(get_pitch()))
And they all follow a similar approach, defined in the Astro Pi and the Raspberry Pi Sense Hat web pages mentioned above.
One mention I'd like to make is on how to get location information while using the Pi board. The Sense HAT has no such feature but given that the Raspberry Pi has several USB ports, inserting a USB GPS dongle is pretty straight forward while connecting and reading location information from the dongle is not a trivial task but neither is it very difficult given the amount of resources already available about connecting and reading NMEA data from a USB GPS dongle.
Hope this info helps.
Denis
Mar 7, 2017 2:25 AM UTC
Hi,Denis
     Thank you for your helpful assistance.This is a very useful example.
     If you want to read any of the sensors attached to the raspberry pi , and then send it to the Thingworx platform via EMS and LSR. First you need to read the data on the sensor with the python script, and then set the property/services in the Template.lua.  Is that right?
     Is it possible to read the data on the sensor directly with lua ,without a python script?
Yours sincerely!
Mar 7, 2017 8:20 AM UTC
Wang, what sort of sensor do you have? I've not done that myself so not sure if you can read it, probably it'll just be about finding the libraries within lua that can do that for you, so that you can directly read from the sensor . Though i feel (may be just my opinion here) python is better equipped with quite a view libraries with useful functionalities.
Mar 8, 2017 11:04 AM UTC
Hi Wang, Aanjan Ravi​,
I am trying Raspberry Pi Quickstart documentation and stuck at Step 10(Run LSR). I am using EMS provided in the guide in beginning steps.
When i am running LSR it starts but it is giving error as
[INFO ] 2017-03-06 17:20:46,870 PiThing: ------------------------------------------------
[INFO ] 2017-03-06 17:20:48,838 PiThing: -- Starting script --------------------------
[INFO ] 2017-03-06 17:20:48,838 PiThing: Registering core callback handler
[INFO ] 2017-03-06 17:20:48,838 PiThing: Starting main loop
[INFO ] 2017-03-06 17:20:48,838 PiThing: Calling lifecycle start listeners.
[INFO ] 2017-03-06 17:20:48,838 shapes.propsubscribe: Initialized
[INFO ] 2017-03-06 17:20:48,839 thingworx.handler: Creating a new handler.
[WARN ] 2017-03-06 17:20:48,943 HttpClient::processReq: Authentication requested but no credentials supplied
[INFO ] 2017-03-06 17:20:48,944 PiThing: Error occured while accessing EMS. Checking isConnected.
[WARN ] 2017-03-06 17:20:49, 46 HttpClient::processReq: Authentication requested but no credentials supplied
[INFO ] 2017-03-06 17:20:49, 46 PiThing: MicroServer is now available.
[INFO ] 2017-03-06 17:20:49, 46 PiThing: EMS is available: true, online: false
config.json
"ws_servers": [{
"host": "guragidev01.strykercorp.com",
"port": 8081
"http_server":  {
    "host": "10.117.255.20",
    "port": 8081
"appKey": "213abab3-a234-4357-a1f7-49e59d6ac8db",
"logger":   {
    "level":    "DEBUG"
"auto_bind":    [{
        "name": "PiThing",
        "gateway":  false
"certificates": {
    "validate": false,
    "allow_self_signed":    true
"ws_connection":    {
    "encryption":   "none",
    "verbose":  true,
    "msg_timeout":  1000
PiTemplate.lua
module("templates.PiTemplate", thingworx.template.extend)
-- service input parameters
-- me: table that refers to the Thing
-- headers: table of HTTP headers
-- query: query parameters from the HTTP request
-- data: lua table containing the parameters to the service call.
queryHardware()
--  if properties are successfully updated, return HTTP 200 code with a true service return value
return 200, true
end
-- use the vcgencmd shell command to get raspberry pi system values and assign to variables
-- measure_temp returns value in Celsius
-- measure_clock arm returns value in Hertz
-- measure_volts returns balue in Volts
--   set property temperature
--  set property frequency
s = s/1000000
--  set property volts
end
queryHardware()
end
Config.lua file
scripts.log_level = "INFO"
scripts.PiThing = {
    file = "thing.lua",
    template = "PiTemplate",
    scanrate = 1000,
    taskrate = 3000
scripts.rap_host = "guragidev01.strykercorp.com"
scripts.rap_port = 8081
Since it worked for you can you please help what is the issue.
Is my below code ok?  When i tried using 127.0.0.1 is was not even connecting to EMS.
What is difference between WS or Http? I am new to Thingworx so excuse me for this basic question.
Mar 8, 2017 11:21 AM UTC
Its working now. I was giving wrong http details. Thanks!!
Dec 13, 2017 6:08 AM UTC
Hi Ravindra singh,
I am getting the same error as above.
Can you guide me how to give those details correctly?
Naveen Kumar
