Thingworx API won't work over self signed certificate
I have a web service which I created using Laravel's Lumen. It receives data and one it does, it sends it to Thingworx via the API. While I was on Composers which use a valid certificate, I had no issues with this, but now I am on a self signed certificate and the API request won't go through. In lumen, I am using cURL to make the HTTP request. I have added
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, false);
lines to my to my cURL request as suggested by stack overflow. I have added
x-thingworx-session=true
to my url as suggested by Thignworx community. Still, the error persists. I have opened the Security Log to see the output and it is saying
 Error	No authType or appKey parameter has been specified for Authentication Scheme: AUTH_THINGWORX_APPKEY
I have the appKey parameter specified in the header.
Does anyone have a solution to my problem?
moonkrjAnswer
Updated to NET SDK 5.5  after having 5.3.1 and after updating to 5.5 added the config AllowSelfSignedCertificates = true; Looks like the issue is with self-signed certificates...
 Currently working with the Java rest api based project (this thread on stackoverflow).
moonkrj1-VisitorAnswer
@davidvojnic
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
