Thingworx Application on Linux and Database(MS SQL) on Windows
hi ,
I am getting authentication error(http status 403 -forbidden), while installing TW8.0 on Linux. I am using Windows as DB server with MS SQL.
What changes need to be done while TW application on RHEL and DB on Windows.
I placed sqljdbc42.jar inside lib of Tomcat. Any changes should i consider before launching the application. please let me know.
madhu
Madhu Nalla​: I believe you have reported this issue with our Technical Support Team and we will be assisting you further on the same.
-Durgesh
mnalla1-VisitorAuthor
Hi Durgesh,
This issue i have not reported to the support.
this is the error.
2018-01-19 17:36:00.576+0100 [L: INFO] [O: S.c.t.s.a.s.SSOContext] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] SSOContext created...
2018-01-19 17:36:00.647+0100 [L: ERROR] [O: S.c.t.s.a.AuthenticationFilter] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not load session timeout from database, using default: null
2018-01-19 17:36:00.662+0100 [L: INFO] [O: S.c.t.s.s.SCIMProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Initializing SCIMProvider servlet...
2018-01-19 17:36:00.663+0100 [L: ERROR] [O: S.c.t.s.s.SCIMProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] SCIMProvider initialization failure.  Thingworx Server is not running
2018-01-19 17:36:01.661+0100 [L: ERROR] [O: S.c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-9090-exec-1] Could not handle request
2018-01-19 17:36:16.499+0100 [L: ERROR] [O: S.c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-9090-exec-4] Could not handle request
2018-01-19 17:36:20.845+0100 [L: ERROR] [O: S.c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-9090-exec-5] Could not handle request
2018-01-19 17:40:56.686+0100 [L: INFO] [O: S.c.t.s.a.s.SSOContext] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] SSOContext created...
2018-01-19 17:40:58.092+0100 [L: INFO] [O: S.c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingworxSSOAuthenticator disabled
madhu
Did this issue get resolved?
I'm also facing the same issue, Can you please help me on this.
Abhiram
